/wwwthreads_images/icons/tongue.gif Several things are worth considering here, Andy. First off, if you run lower axle ratios, the driveline DOES have less work to do.....the torque will be less with a 4.56:1 than with a 3.73:1 axle ratio. So in that view, a lower axle ratio is a plus. There is, however, a problem with using a lower (and in this case I mean lower SPEED, not lower numerically)axle ratio, and that is that the pinion speed goes up and that's a disadvantage in a sustained run across country, AND....there is less of the pinion gear TOUCHING the ring gear. Low ratios mean smaller pinions, and that means less metal does more work. We used to get into this when we ran trucks with big gassers for power. The 392 Chrysler Hemi was a big favorite, but it DID have a higher cruise/pull RPM than did the 413 Chrysler non-hemi. The difference in RPM made the rear axles behind the 413 a slightly higher ratio, and they lasted longer because the pinion speed was lower. The other side of that issue is the gearbox, and you can manipulate that endlessly. I set up my favorite truck with a four-speed brownie with double-under for extreme power, but the problem was that if someone else drove it and was not careful pulling through a tough spot, they blew the driveline out just behind the brownie from too much torque caused by the extreme reduction. Of course they couldn't just blow a driveline....it had to whip around and puncture an air tank too and lock up the brakes and.......well, you get the idea/wwwthreads_images/icons/frown.gif Personally, I still like to take the reduction in the gearbox, and have a higher rear axle. I feel that the axle will be stronger for it, and I would rather blow a DRIVELINE and fix it than blow out a rear axle pinion gear and be really stuck./wwwthreads_images/icons/smile.gifWhether they realize it or not, when a Jeeper goes to a bigger axle, he is attempting to over come the shrinkage in diameter that the pinion in his own axle would experience if he went to a lower gear in THAT axle. By starting with a bigger axle, he can have just as much gear surface if not more even after going WAY down in ratio. So you can see that if you are looking for a slow-speed axle, there is absolutely no substitute for size./wwwthreads_images/icons/smile.gif Try to imagine what it takes to put 450 HP to the road at only 700 or 800 RPM like a Diesel truck does. Is it any wonder that they use 1900 Series Spicer 8-Bolt U-Joints?/wwwthreads_images/icons/crazy.gif
