Re: Looking 4 trans/xfer case bolt pattern dimensi
Well, I'm only getting rid of it because of the front locker. I do plan to eventually use part of it though. I'm going to machine a plate and a couple of shafts etc. to mount the low range unit to the pto port of the dana 18. The 700r4 is the same length as the 400 which means i don't have room for a gear reduction between the trans and transfer case. It will make a good winter project though and might be ready to install in the spring. With that and the 3.54 gears in the axles I have sitting here, I'll have a total reduction of 68.5:1. If I swap to lower gears later, it will be even better. Right now I have the 400 with 4.1 gears. The interesting thing is with the 700 and 3.54 gears, the first gear, direct, final drive ratio is almost identical.
