Looked at the Superlift 6\" ZR2 lift at their plant
Well, boy's & girls, Tom's at it again!!!! Superlift is in Louisiana and so am I, so I went to Monroe today and looked at the new 6" kit on the SEMA SHOW 2000 ZR2 Blazer today!!! Well, it should be released by the end of next month to the public. I am sending photos of the brochure on here to go with it. Here's the Skinny.... It's a real beefed up version of a T Master kit, but not in pieces like theirs on the mounts & stuff, solid crossbracing all the way. They wouldn't let me get photos, but, it has a adda leaf in the rear between the eye spring & 2nd spring out of a full-size that is thick like our springs and a bolt on spring flip block kinda like a Tmaster kit. Then a steel braided brake line on it. "Not a quote on that, the tech guy was out and the other tech guy said he thought that the braided line went with it for the rear." And 2 big shocks for the front & rear. There are sway bar relocation brackets that are done right and look factory. The Tbar crossmember is re-used and lowered, but not hung by rubber like stock and solid and side support too, REAL NICE. On the front the prototype had a stock upper A arm on the left which is being replaced by tube Arms. It had a tube one on the right and the R&D guy had 2 new ones on the table alreaady bent for both sides and a dual shock hoop laying there for them. The Tube A arm that was bolted in place on the right for now had the provisions welded in place for the dual setup but not finalized yet. Next, they should clear the rear factory offset no problem from the same configuration almost as the stock A arm, but tube. The longer shocks that were on there were relocated almost straight up and down and moved in with a nice bracket that fits inside the stock tower and a lower bracket that bolts around the lower A arm. The upper relocation brackets had gusset braces in one bracket as of now and not both, but as I said this is the prototype and still being added to. The original for the show used the stock upper A arms and all that was in tact and looked good enough for sale "as is". But they ARE providing us with Tube ones. Next is a new centerlink that has dual links to keep it strong. There will be an optional steering stabilizer that will replace the stock one that looked good. The "optional Skid plate was nothing but an added plate on the bottom of the whole thing and still had the factory composite one above it. I suggested how 'bout a toal rebent replacement skid plate to cover all the bottom and turn up to replace the factory one too. But as I said the project manager for this kit was not available for comment and it may get that. For the front brake lines it had 2 6" extensions that go between the rubber lower and top steel. I don't know if we will get braided to replace that either. This truck was built in short of 2 weeks and hauled to Cali for the show. The one in the scans I'm posting was the real Macoy that was beat to death, "notice the broken centercap" and was a stick shift. The exhaust has to be routed around the front driveshaft of course. The stick was a perfect truck with NO TROUBLES "AT ALL". This show truck is an automatic and had noticeable driveshaft vibration below 45 MPH. When I looked at it the stock rear drive shaft looks too short. The guy said they had played with the pumpkin alot before and couldn't get it out and thought the driveshaft was bent or not balanced or something. It may also be too short he said. Right now they don't know. But all the Z71's have to get a drivshaft fixup by the owners when you get a 6" lift. So, for now, we have to wait and see if the bug is worked out and he didn't know or what. I'm going to call next week and talk to the guy personally that's R&Ding the ZR2's. They have done trucks and no problems and I saw pics of them. Just the Blazer is so short. Not a quote but the price is hovering around $1400 with everything included & waiting to see on the driveshaft bug. They want to have the multiple shock setup finished before releasing it to the public so you can have the option right up front. As I said, I will call and find out for everybody. I was told the guy is kinda slow, but I've seen his work and it's worth the wait. This truck has no body lift and 33 BFG on 10" rims almost under it and will do 35's no problem. If you call about it you won't find out more than I have put here. Plus I have a guy on the inside that works days and nights there. I will keep eveyone posted. It's a 3.5 hour drive for me to see. As for the 2" ZR2 kit like Rocknroadn, it's available now for $490.11 in stock.
