/wwwthreads_images/icons/tongue.gif It did not take me long to determine where the weak point was in the Quadra-Trac system. In order to make it so the driver had LESS CHOICES to make, they put in some cone clutches in the center differential to make it TRY to lock up a little when you give it a lot of power and one axle has very little traction.....like pulling out of a service station with gravel on the pavement......so the stupid driver just had to sit there and the transfercase does all the work....theoretically..... BUT the PROBLEM is that the center differential holds A LITTLE BIT, ALL THE TIME. And that makes the system sort of "tight" due to tire mismatch. Every time the stress builds up to a certain point, the clutches POP loose and the differential gears move all at once to a different spot. If you are trying to engage "LOCK" or what is called "Emergency Drive", the teeth on the slider cannot ease into the differential housing, but must wait till it slips, and then try to get in. Usually the clutch POPS ahead too far and the vacuum operated slider just gets a corner of the spline and any power applied just blows it back off. FOR THAT REASON, we are disabling the clutches and going totally open center just like the '97 Grand Cherokee that we love to drive in snow so much. It has open center and can be locked manually. On our Quadra-Trac we are also setting up a cool indicator lamp system that shows: Green-Open; Yellow-Has vacuum signal but has not shifted as yet; and Red-Locked. That way, Jeepchick will know when to stop turning figure eights to get the vacuum operated collar in or out. She will select the mode, and watch for the yellow to turn to red or green before she gets back on the throttle. It's a great transfer case, but those clutches have GOT to go! /wwwthreads_images/icons/crazy.gif And yeah, we DID consider rear locking hubs, but we would also have to go to full floaters. If you blow the rear hub or axle, you CAN come home in front drive, with or without the rear driveline if the QT case is in "lock"./wwwthreads_images/icons/smile.gif
