Ive been thinking alot about lifts, which one to get, wich one to recommend to people that ask, etc. I have gathered a little information about these lifts (for '88 to'98 trucks) to give me a better perspective on wich ones are good for what(show/durability/angles/accual lift height). I would like for you to add to this if you can. I also fully welcome any contradictions if you think any of this is wrong, or if you have had good luck with yours. Keep in mind that most of this is the opinions of installers and owners and not my own.
Rancho....
PROS: 1 piece subframe, great finish, good springrates with optional springs, Keeps angles fairly stock for durability. Overall a good lift for the money.
CONS: steering and balljoints wear abnormally (they probably used 36" tires and 10" rims though), lift is accually 5", skidplate??.
Superlift......
Pros: Good finish, lift height is very close to advertised,
Cons: Ride is harsh, steering wears fast, no 1 piece subframe.
Trailmaster......
Same responses as Superlift but it is cheaper and the parts seem weaker.
BDS......
Pros: Best darn warranty around, Good durability
Cons: Expensive
I couldn't get much info here, would appriciate more.
Full throttle suspension.....
Most common answer: Never heard of 'em
Rough country......
Pros: Cheap
Cons: Metal looks flimsy, hard to install, steering angles all goofy.
EZ-Ride
Most common response: Good kit, not too hard to install, seems and so far is durable, "youll definately want to order the springs"
Pro Comp.......
pros: close to advertised height, good finish, great skidplate, seems strong.
Cons: quite a few people mentioned thumping noises that lasted throughout the lift's life starting at install, lots of bad balljoints.
If you have anything to add please do so.
>>>>>>>>>>>>>>>>>>>>>>>4x4
Rancho....
Superlift......
Trailmaster......
BDS......
Cons: Expensive
Rough country......
Pros: Cheap
EZ-Ride
Pro Comp.......
>>>>>>>>>>>>>>>>>>>>>>>4x4
