Replacing my tired 4" procomp lift. Thinking about a RE extreme duty 4.5", 1" lift Revolvers, MORE SRS, and 1" MORE body lift. My ? is, will I be able to fit 35X12.50. This will be a total of 6" lift. Thanks in advance.
I see you just joined the board, welcome.
I think you may need a bit more clearance to fit those 35s. They may just fit but I think they would rub pretty bad especially with revolver shackles. Or you could trim the fenders. Check out http://www.rockcrawler.com to see what other YJ owners did to get 35s on.
Jason.. I have 5+ inches of lift, and i can rub 32's against the flares.... i could probably fit 35's under my jeep, but i'd have to lower the bumpstops considerably to do it. The other item you should look into, is putting TJ flares on your Jeep... the give some extra clearance on both ends, have to do a lil trimming, but the look great, and will make it easier to fit 35's
Good luck
BJ
"If you chose not to decide, you still have made a Choice" RUSH
