Was thinking about which jeep to bring to the jam this year, and I needed new springs anyway, so after the winch and soft top I decided to go with a SUA lift on my 73 Commando. I know, SUA, but my teenager will be driving it and I wanted to keep it more stable. I ordered alcans (4" lift rear, 3" front), brake lines, wheel spacers, drop pitman, etc. My springs are 2" wide (front) and 2 1/2" (rear).
I've spent a lot of time using the search function, but still have questions.
Shackle bushings - I just want to replace the upper ones I have, but not sure of a good source to get them. Also, not sure what the spring bushings are going to look like, but I may need to shim/bush the gap between the spring and the shackle. Any recommendations? Should I just bite the bullet and buy heavy duty later CJ units? Are they the same length? I don't want lift shackles.
Shocks - I know I am going to need longer ones - any recommendations? Do I have to move the mounts with a SUA lift?
Driveshafts - With 3" lift up front, will I have to lengthen the driveshaft? In the rear, can/should I taper shim the perches to angle the pinion up and maybe not have to lengthen it?
Appreciate the help - thanks in advance.
