Starting from how much lift will I need a dropped pitman arm?
thanks
thanks
In reply to:
I kept soaking it in PB Blast and learned a new trick. With the last puller, I keep slowly adding pressure on the puller till it was close to busting. Then I tapped/hit the outside of the pitman arm by the splines with a small sledge and eventually it will let go.
[/ QUOTE ]
That's not a "trick", that's how you do it. The end of the puller screw is made to be hit. When you hit it, the shock transfers to the shaft having the exact same effect you did by hitting the side of the arm. If you were only tightening it down until it snapped, you were doing it wrong.
In reply to:
It didn't come with directions so I guess that makes me pretty smart for figuring it out on my own.
[/ QUOTE ]1. I'm sure you said this "tounge in cheek", but
2. As I've been saying for years:
3. "You're your own best mechanic."
4. Your as smart as most mechanics,
5. If not more so,
6. So pat yourself on the back,
7. Multiply the knowledge by
8. Helping out others when needed.
9. You have done well, but you can do better...![]()
