Guest
·I'm swapping in a D44 out of a 78 Blazer 1/2 Ton. The passenger side tie rod end is right hand thread and the driver side is a permenantly affixed tie rod end. I am going to use a dodge flatop knuckle and the arms to do over the springs steering. I'd like to use chromoly or DOM tubing for the tie rod and need to find a left hand threaded tie rod end preferably of the same size/dimension/strength as the stock Blazer passenger side one. Do any of you swap gurus have any idea if Dodge or Ford made a left hand threaded half ton or 3/4 ton tie rod end? What about the tie rod end on the draglink of the Blazer? Any chance it's left hand thread?
Thanks,
Sean
Thanks,
Sean
