OE APPLICATION LED LIGHTING FOR THE F150 FORD RAPTOR
WE ARE A SUPPORTING VENDOR... LOOK FOR MORE INFO UNDER THE SUPPORTING VENDOR SECTION OF THIS FORUM
Rigid Industries - LED and HID lights
Raptor Fog Kit-4400 lumens
Dually LED Fog light kit , mounts in existing fog openings in the lower corners of the bumper utilizing aluminum mounting plates. Two lights per side, your choice of white or amber color, and spot or flood pattern. Wire harness, mounting brackets and all necessary hardware included for installation.
Raptor Lower Grill Kit-7200 lumens
Lower Grill 20" E-Series kit, mounts in existing lower grill opening. Simply remove the lower grill(5 screws) and install our bracket/light kit. One single 20" light, your choice of white or amber color. Our 20" E-Series has a combination of spot and flood reflectors for an excellent light pattern up close and in the distance. Wire harness, mounting bracket and all necessary hardware included for installation.
Raptor Upper Grill Kit-14400 lumens
Upper Grill 40" light mounts behind upper grill. This version mounts to existing mounting holes on either side of the inner frame assembly. 40" E-Series, your choice of white or amber color, comes with a combination of spot and flood reflectors for optimum light coverage. Wire harness, mounting brackets and all necessary hardware included for installation.
