First thing bro, if your plugs are white, PLEASE put a bigger main jet in, you are way tooooooo lean. Its better to go too rich than too lean for starters anyways. If your not running the stock air box, its so easy to change the jets.
Second thing, I got in to the hype about installing bigger pilot jets (32.5 up from 25 stock, and it constantly stalled and fouled plugs). I have recently gone back to the stock 25 pilots, and it never fouls or stalls. Youll find out for yourself.
By the way, are you running a twist throttle, and or have you removed the TORS carb caps?
-cleartoy
Also, what kind of gas do you run with 19cc domes?
-cleartoy
