1 - 20 of 31 Posts
just wanted to reasure everyone that even tjs can have leafs and rockwells that flex like arnold
im curious as to how he gets away with no traction bar to stop axle wrap
maybe i just dont see it
makes me feel better about inboarding the rear leafs and not having links
Mega flex & 1200 + RTI ramp scores aint everything man.......
Just ask a few vets that have built RTI busters. If they say its great to top 1200 then they are not running trails they are mall crawlers!!
i know rti ramps dont mean sh!t, im just showing off a jeep that i like and making everyone with leafs feel a lil better knowing that they CAN flex good enough. lots of times too much flex will hurt you becuase theres no pressure on that tire and its just stealing pressure from yer other tire that could help you move. lockers are where its at
and does that last pic look like a rti ramp?
well yeah it does
, that rig is from pirate and he wheels it , used to have d60s and 39 boggers now its got rockwells and 44s
Discussion Starter · #15 ·
yep rockwells, same axles i have and im goin leafs thats why i posted this
Discussion Starter · #17 ·
its a disc brake like a monster truck uses
it gives you 6 times more braking power than a disk at each wheel due to the gear ratio
theres a few setups you can use, in the pic that is a toyota ifs caliper and a mazda b2200 rotor which i will prolly use
but i just got done cleaning the spider gears from one of my rockwells so i can weld it, still pondering on which way to weld it
you will be glad you are welding and not buying Detroits.this guy broke both a front and rear Detroit and they would not warranty them.so he chunked them and welded his diffs and has had no problems.
Discussion Starter · #19 ·
the two reasons im welding is #1 im going pinion brakes and if i have a detroit it unlocks and both tires will not be getting stopping power and it will be sloppy
reason #2 which is obvious is its basicly free
Butcher
Here some flex for ya, their not leafs but its pretty funny how much flex it doesnt have. From the Detroit Auto Show:
1 - 20 of 31 Posts
