Diode Dynamics is excited to introduce our new Stage Series SS3 Fog Light Kits for the 2016+ Chevrolet Silverado!
Fitment:
- 2016-2018 Chevy Silverado 1500
- 2019 Chevy Silverado 1500 LD
Fitment:
-2019-2021 Chevy Silverado 1500
-2020-2021 Chevy Silverado HD 2500/3500
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the SS3 collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS3 serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the SS3 is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Click HERE to check out the SS3 LED Fog Light Kit for 2016-2018 Chevrolet Silverado 1500!
Click HERE to check out the SS3 LED Fog Light Kit for 2019-2021 Chevrolet Silverado 1500!
Click HERE to check out the SS3 LED Fog Light Kit for 2020-2021 Chevrolet Silverado HD 2500/3500!
SAE Compliant. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
- SAE Driving is designed to supplement your high beams, but it's great for general illumination as well. Rather than a traditional "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to fully illuminate the road ahead at high speeds.
- SAE Fog provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of cool white or yellow, which is often said to help cut through inclement weather.
When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow. All Stage Series LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
Sport, Pro, or Max. Stage Series LED pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses high-intensity LEDs, and is the best bang for the buck you'll find. The Pro model steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, for both high power and extreme intensity. This brand new technology comes at a cost, but if you're looking for the absolute best in lighting performance, the SS3 Max is the answer.
Stage Series 3" SAE/DOT Type SV1 Fog Light Kit
In the Box:
- Two (2) SS3 3" Standard LED Pods
- Two (2) Molex Wire Adapters
- Two (2) Type SV1 brackets
- Mounting hardware
- Mounting guide
See how to install our Stage Series 3" SAE/DOT Type SV1 Fog Light Kit!
Stage Series 3" SAE/DOT Type SV2 Fog Light Kit
In the Box:
- Two (2) H11 DT Adapters
- Two (2) Type SV2 brackets
- Mounting hardware
- Mounting guide
See how to install our Stage Series 3" SAE/DOT Type SV2 Fog Light Kit!
Plug and Play. Thanks to custom-molded brackets, the SS3 Fog Light Bracket Kit can be installed on your vehicle in minutes. Simply remove your factory fog light assembly and ours will bolt right in its place! Two Molex adapter wires are included with the kit, allowing you to connect the lights to your factory bulb sockets - no additional wiring needed!
If you have any questions, please don't hesitate to post, PM, or email [email protected].
Thanks for looking,
Diode Dynamics
