Well just found out this weekend that I lost my free storage space next door, so some more of this stuff needs to go...
Most everything is best offer or trade, the more stuff you take away the better the deal gets…
Everything is located in western, NY
I have pictures of a lot of the stuff at:
http://www.geocities.com/eimages23/gallery.html
DRIVETRAIN STUFF:
- '65 Corvette camel hump fulie heads, # 3782461, ported/polished, high compression springs - 250
- Early '80's SBC Alloy intake, w/quadrajet carb - 60
- Accel Dual Point Racing Distributor, Cap & high voltage coil - 95
- Clark 5-speed - 900
- T-150 - 25
- Dana 300 wo/shifter - 175
- Stock Dana 300 gear set - ?mo
- Dana 20, 52k miles, very clean, custom hurst shifter - 185
- Dana 20 w/shifter - 90
- Dana 20 wo/yolks - 45
- 79CJ7 Dana 30 disc brake setup, inner/outer knuckles, 6 bolt hubs, inner/outer knuckles, spindles, discs, calipers, except lockout hubs - 50
- 78CJ7 outer knuckler - 25
- 2 - 6bolt hubs parts pile, 1warn, 1jeep, not sure what is missing, 2 coffee cans of parts - 10
- '70/'71 CJ5 Dana 44 axle shaft, 5x5.5 lug - 40
- 4 - 15x8 wagon rims w/31" AT tires - 200
or $1750 for the pile of stuff
- Rear CJ7 tailgate no rust/straight, was spot welded - 25
- Manual steering box (77cj7) 52k miles w/drop pitman arm - 100
- Manual steering box (78cj7) w/pitman arm - 35
- AMC v8 Air cleaner assembly, air cleaner, mounting stud, painted yellow - 35
- J-truck brake proportioning valve (disc/drum) - 35
- 2 drive shaft loop/catches for CJ7 - 30
- Bestop Rear Section (3windows) & Bows, old 3 piece style- 70
- 258 engine mounts - 25
- Grab bar black -6
- Grab bar older chrome - 3
or $250 for the pile
M715 Parts:
- Set of original rims, w/Denam NDT DOT 9x16.00 tires, like new - 425
- Stock radiator and cap, mint condition - 125
- Complete wiring harness, including the flasher box - 125
- M715 rear axle shaft, new mill surplus - 50
- NP-200 divorced tcase, passenger side drop, 1.96:1 low, 17k miles - 225
- Full J-truck Heater system, ducts, core, blower - 85
or $750 for the pile
MISC:
- 1981 BMW 320i drivetrain; 110k miles, fuel injected 4cyl, wiring harness, computer, 5-spd tranny, driveshaft, all accessories - $725
- Austin-Healy 100-6 Hardtop, noliner, vintage - make offer
- Traction bars, heavy duty for Dana 60 (like on drag cars), has spring stops, shock mount stud and 1/2" u-bolt plates built in - 75
- 15" JBL Pro sub, needs rebuild - 75
AUDIO STUFF:
- Concord Radio w/small external amp and RCA inputs - 15
- Clarion tape deck - 5
- Dual 15" sealed sub cabinet for CJ7 jeep, w/Kicker XPL Subs - 350
- Dual 15" DJ Cabinet black w/casters, w/Peavey Black widow subs - 225
- 15" EV sub, needs new basket assembly - 25
- 2 - Large circular Loudspeakers, ~22" diameter, 9" deep - 25
- RCA loudspeaker, w/Lafayette driver, front 20"diameter, ~16" horn depth - 35
- Pair of BOSE 101 music monitors, 10-60wrms, 4ohm - 80
or $550 for the pile of stuff
Other stuff:
fuel press regulator, guage, and some braided line; tcase shift boots 20/300;
bellhousing inspt covers, buick 350, t150; shift floor plates, grab bars, crome, black;
SBC water pump, WW1 campaign hats
Luke
'77 CJ7 SOA Chevy 327
http://www.cj7jeep.com
DRIVETRAIN STUFF:
- T-150 - 25
- Grab bar black -6
M715 Parts:
MISC:
AUDIO STUFF:
Other stuff:
Luke
