If your jeep is 81 or newer you should be able to use the YJ doors . The tubs are very simular, both having post reinforcement behind the door opening where the post bolts on. The old style used a paddle latch. The only thing to do shopuld be to hang them and enjoy.
The half doors I bought worked fine. They use the same post. Unless yours are a strange aftermarket stlye it should latch the same. My friends 1/2 doors work the same as mine.
tj's have the u-shaped pin that the door latches onto, the yj's have the striker bolt should be the same as you cj
'95 Jeep Wrangler Sahara
