/wwwthreads_images/icons/smile.gif We are primarily SNO drivers up here and don't really do much rock running at all, but it occurred to my engineering mind; after reading so many posts on the need for good articulation; that it may be desireable to use a rear axle setup very similar to the early Ford cars with the enclosed driveline and a wishbone to hold the rear axle. You could use coil-over hydraulic suspension which would transfer oil to the side of the Jeep which had to go deep and relieve the side that had to crawl over. Coils would just add some bias to the process for stabliity, and for hiway work you could use a cut-off valve in the oil lines to cancel out the transfer of oil. The enclosed driveline IS the torque tube and takes all of that strain off the axle tubes entirely, and the springs only have to hold the up and down motion, no torque, since the torque is strictly between the piggy and the wheels themselves. The idea here is twofold: (1) to provide for more tire contact and articulation; and (2) to keep from having to wrack the frame and leaf springs to get articulation. This setup would especially adapt itself to the TJs since they have coils already. The enclosed driveline would not actually be totally enclosed, but rather "encaged", where the cage is the torque-resisting member and a skid at the same time. Sometimes you gotta let your brain float a little and try not to think of what IS being done, but what CAN be done/wwwthreads_images/icons/crazy.gifYou could also take a page out of the (UGH!)"Low Rider" book and use four hydraulic cylinders as your coil-over hydraulic suspension and control all four corners independently from the driver's seat. All you would have to do is steal a bunch of tractor batteries; steal the hydraulic power packs from several trucks with lift gates; steal the switches and the solenoids and you'd be set./wwwthreads_images/icons/tongue.gif
