Well I finally made progress on the jeepster this weekend (wife gone for the weekend and only two jeepsters owners stopped in for parts). I finished the Lee power steering conversion with hydraulic ram assist and installed the new 9" Navaho power brake booster and master cylinder, hooked up the new front driveline to the Currie 9" front axle and took it out for as ride. Wow what a difference in the steering from the old manual Saginaw steering and the 4 wheel disc brakes work great. Next weekend is a three day weekend and should have the ARB compressor mounted and wired for the front axle, mount the new 9000 lb Warn winch and fix the wiring (brake lights, horn, turn singles, wiper and heater)
Less than 3 months to Moab
Chris, the pump came with the complete Lee steering set up. It included the ram assist cylinder, all the hoses, fittings, the pump and pulley, the external oil reservoir and the gearbox. It looks allot like the ARG pump. You can get that one at 4 wheel Drive Hardware. You can also buy Lee products from these guys.
www.mckenzies.com/page25.html
-Don
