Re: isuzu p\'up V8 engine swap
Your gonna be in for a long install.Ive been wokin on mine for about three years now,mainly cause I get discouraged and let it sit for awhile.Im pretty close now.As far as the axels, thats what Ive been workin on here recently.After snappin the rear I decide to redo the whole suspention.After a long junk yard search I found out that early 80 model Wagoneers had the same exact width axels and were six lug ta boot.The ones I used are a dana 44 for the front and a AMC20 in the rear.I went ahead and put the rear one under the springs for lift.The Jeep dana was a spring under but instead ot switch in it I just tried to mount it so that it came out level w/th rear.All of the braketry for the motor mounts,tranny,and axel mounts I just made it up as I went and fabricated as needed.You will still need aBFH for the fire wall to clear the bellhousing on the tranny.I accually got my engine in far enough down that I can shut the hood no problem w/the air cleaner.You will still have major issues w/ the radiator cleance to.There justisnt enough room front to back w/the V8.I have to pull the radiator to change a belt,not good.I am also finding it diffacult to find a place for teh tranny cooler.There is no room in front of the radiator at all.I think my overall lift after the axels are in is around 7ins.I wish I had some pics for ya,maby I could use my dads dig.cam and send ya some.The engine really wont firt at all w/the Ifs front axel,it hits the oil pan.I did get it in but only after adjusting the pan w/the same ole BFH.I am also havin a hard time w/the pass side ex. manifold because of the starter and the engine mounts-very little space.The drivers side is fine.I really dont know how any of this would be w/ a 351, it may be completely different.One thing that will help your install a bunch is a body lift.I didnt think about it until I was doin the axels.It would make the clearences way easier.Well I'm ramblin on again,I just cant write down all of the things that I've modified on this Trooper.Well I gotta go,let me know if you got any more Qs.
RB
