I WAS LOOKING AROUND ON THE WEB AND CANT FIND A KIT THAT
BEEFS UP A DANA 30 FRONT END ON A 88 WRANGLER. I SEE A KIT
FOR A CJ THAT REPLACES FRONT SHAFTS BUT NOT ON A YJ.THE ONLY THING
IS SEE IS THE HUB CONVERSION KIT AND FOR THAT MONEY ILL MODIFY
A AXLE TO FIT.DOES ANY ONE KNOW WHERE I COULD GET ONE FROM???????
I don't think there is much to be done that will really help, if you need to beef the front end then you probably need a dana44.
Front and rear axles from an '80s grand Wagoneer are almost a bolt in for a YJ. You'll only need to move the spring perches on both axles -
and only about 1/4" on the front. This is a more cost effective solution than throwing thousands of dollars at the stock axles.
Nutter, is there a thing that shows the setup and installation of the axels from a grand wagoneer to a YJ? I don't know much- but what type of axle is the grand wagoneer?
