Guest
·I get home from work yesterday, and there's a box wrapped with a bow on my workbench. ?. Turns out, it was a little "just because" from Jeepchick. Awwwwww.
It's a nifty little device, really. It's a 1/2" wratchet that is basically filled with a bunch of spring loaded pins. Therefore, it'll fit ANY bolt from 1/4" to 1/2", INCLUDING stripped or deformed nuts and bolts. As you put the socket over the nut or bolt of whatever size, only the necessary pins depress, and the remaining pins act as "filler" between the outer walls of the socket. So basically it's a one-size-fits-all standard/metric/warped/stripped socket. Sweeeet! I'm sure it can't handle extreme pressures, but it's a handy little sucker. And it came with a 3/8" wratchet and high speed drill attachment. She ordered it off the TV, but I can try and find from where if y'all want.
canis
'82 CJ-7/360/727/D300/cobra, M.O.R.E. shackles, 1/2" steel bumper, 1" body lift and lots of ideas!
'96 ZJ - 4.0L/42re/np242/optima/cobra and other goodies
canis
