Guest
·OK... this is entirely Hypothetical (for now) my idea is to make a completly free floating rear axle. Make a one link Rear end, with no solidly mounted springs. Something that attaches (solidly welded) to the rear axle in 4 points (on top, and under the axle, near the current shock-mounts) and one pivot (similar to a pintle hitch), located near (either over or under) the front of the driveshaft. For the springs, i was thinking something like a 1/4 elliptical spring, and then a good size pad (teflon covered) for them to rest on. This would allow literally unlimited droop (limited by shock length, Axle length if you want to get reallllly crazy).
Any plusses or minuses to my idea??
How about any other ideas?? These are all hypotical for now, so give me your Craziest, Off the Wall ideas, I might end up using them for an engineering project eventually
Thanks everyone
BJ
PS, any more Clarificatoin needed on my idea??
PSS, I've read all that stuff about having tooo much Articulation.
"If you chose not to decide, you still have made a Choice" RUSH
Thanks everyone
BJ
