Yesterday the temps were -36F. Today -24F. Today the charging system quite. I havn't looked at it yet other than to confirm the belt is still on. A slight squeel was heard while driving it.
My first concern is to tow it home and get it on a charger before the battery freezes. (I drove it several blocks to get me to work and a WARM, SAFE place, so an uncharged optima battery is in. Do optimas freeze?)
Does anyone have any experience with alternators in the cold? Regulators? I am kinda electrically challenged, so any input would be appreciated.
BTW, recently I tightened the belt, the alternator would squeel when lights, defroster, radio and charging were all taking place. I eliminated the squeel, I don't think I overtightened the belt, very dificult with the OBA and the homemade brackets and idlers.
Don't you hate it when things stop working in the cold. Bring it in somewhere warm, charge up the battery. Make sure it will hold a charge. Might take overnight to charge it up. Test it under load. Ie, cranking motor or with lights on. If its ok, Look over the wiring to make sure everything is in place. I'm assuming a GM type alternator: Check for 12volts at the two terminals (bat and red wire to two terminal plug). Make sure the terminals are not corroded or loose. The dark wire that goes to the two terminal plug also gets 12 volts from the key on power on the harness, but it is through a resistance wire to prevent it from keeping the ignition running as it puts out alternator voltage once it is operating. You can do a temporary hookup straight to your battery just to test it. Start it up and see if there is an increase in voltage at the battery. It should go up to or above 14 volts with the engine running, compared to around 13 on a charged battery. If the wiring harness looks good and it still doesn't charge, then remove the alternator and take it into a shop to have it tested.
Went out to tow it home, and jeep started, Temp now about -8F. I am also getting a reading of about 7-8Volts, when before it was consistent at 14V.
Everything seems to spin OK, I don't have a clue.
· Official Curmudgeon
I'd guess that you have a diode shorted in the alternator. Mine did the same thing the first night after I bought it. You might try a test we used to do. Start the engine, turn on the headlights and then remove the ground cable from the battery and see if it will stay running. If it won't, the alternator is not producing enough current.
