Guest
·For some unknown reason, when I now turn on my lights my right-hand turn signal indicator (the little green arrow inside the speedometer) light comes on and stays on. I if use the flashers or the right blinker, the indicator light blinks but returns to solid green after the flashers or turn signal are canceled. This is an 1986 cj-7 that is rarely driven and even less so at night. I now can't remember if both indicator lights are supposed to be on and blink when in use or the right-hand side on is stuck on. I removed the flasher relay-fuse and the condition still exists. This problem seems to have no effect whatsoever on the operation of the turn signals or flasher--they work just fine.
Thanks in advance for your help.
