I have got an 87 pathfinder mostly stock and I want to see if i can get the front end level with the back. I think it has something to do with the torsion bars. If so can someone explain how to increase them.
Any Help Apprieciated
Matt
The proceedure should be outlined in your service manual. It is pretty easy, all you need to do is crank up the adjusting bolts a few turns on the back of the torsion bars. the manual should give you a better idea.
Yep, and if your unsure about doing it yourself just take it in for an alignment and ask the shop guy's to do it for ya, they more than likely won't even charge you for it!
Chris J.
/wwwthreads_images/icons/wink.gifIt's not the Biggest, but at least I use it!/wwwthreads_images/icons/wink.gif
