in need of a winch
561 views 9 replies 3 participants last post by  ducmon900
I just got back from a ride today and i told myself it is time for a winch. I spent at least a hour digging and jacking to get my jeep out of the suction mud. I have seen worse stucks and have even helped guys out of worse but i would have felt better hooking the winch to a tree. I dont want anything smaller then 8,000lbs. Should i go bigger? I dont know anyone with a winch so i cant ask them what they think about theirs. What manufacture is the best and what is it like to get parts from them. Thanks again.
#3 ·
Look around and find a used one, preferably a ramsey or warn. There are also different drives to each one, worm gear and planetary gear (if I remember right) so you'll want to do some research. At full draw when winching they can draw up to and beyond 450 amps, so you'll want a high amp alternator and a good battery (preferably two). A good investment is a pully block also, this aides GREATLY in winching and they run about fifty bucks. I have a ramsey pro9000 that I used to run on my wrangler with a single optima battery and a 90amp alternator. This works okay if your just getting yourself out of mud and such and will get you by until you can get an extra battery. Hopefully teamrush and cjdave see this post, they both have some good insight into alternators and winching. later ken
#5 ·
You want to know what rig well here you go. 1980 cj7 stock 304, an auto shifting for me, 4in superlift, 33x12.50x15 superswampers tsl's, and well axles i havent touched them i am still not sure what i want to do with the rears yet. The hole was ankle deep in the middle and waste deep in the ruts. can i say bottomed out.
#6 ·
lift / tires / lockers / axles will just get you further into the bottomless pit, but only a winch can get you unstuck. I'm getting to the point where I can go so far before getting stuck that its hard for everybody else to get me out, so I think its time for a 150' of cable attached to a milemarker... /wwwthreads_images/icons/wink.gif
Florida Mud CJ-5
#7 ·
I can't believe someone said you don't need a winch. In the last 2 days during our rock crawling competition I winched out a Hummer, a VERY built Toyota, and a VERY built CJ-7, all on the same obstacle. There are some places that the ONLY way out is a winch, and you sure as heck better have one or have access to a big helicopter. If you are going to do any serious wheeling, a winch is MANDATORY, or you better have friends with winches. I guarantee it you WILL get stucksooner or later.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
#9 ·
Any winch is better than none, but I'd get at least an 8,000 pound one. I have a cheap winch, bought it used, but it works well. When I decide to upgrade, it'll go on another jeep, but you could also sell it and use the money towards a larger one. An 8,000 pound winch will work in 99% of the situations, I have only seen them stall out once, and the second 8,000 pound winch we hooked to it was straining as well, so he was STUCK!
JEEPN
'81 CJ-8 Scrambled!
GM151/SM465/NP205 twinstick/7" Lift/33"Swampers/REP 8000/RS9000's/Scout II D44's w/4.10's & Lockrights
