where is the ignition switch.....is it where the key turns...or is there a switch or box under the dash..Im running a wire from an msd igniton box to the + on coi,l then to the "ignition switch"???.
Is there anyone runnin a msd ignition with their prestolite dist...please let me know....thanks
on your '78 Scout II the ignition switch is mounted on the steering column. There is a metal rod that goes from the key switch to he ignition switch. Stick you key in, work it on an off and feel for the metal rod which will lead you to the ignition switch.
If your not living on the edge, you're taking up too much space.
