What kind of accesories are you using when the fuse blows? It sounds to me like a short in one of the circuits that are working off that fuse. How long does it usually run before the fuse pops? Do you have a chart or similar item showing what fuses in the fuse block go to what system(s)? This will be an invaluable tool in finding out what the problem is. I doubt that it'd be the ignition switch, but if it has a short in it, it could be. More likely, in my opinion, and from the experiences I've had with wiring and fuses, it's a wire that's shorting out somewhere (this will be after the fuseblock, otherwise it'd just burn part of the wire instead of blowing a fuse). Good luck finding/fixing the problem. Hope that helped...
Tim
"The_Sandman_454"
/wwwthreads_images/icons/cool.gif '79 GMC Suburban 4x4 and '85 GMC S15 4x4
