*I have the module from my '77 CJ 258. Will it work with my '79 Wag 360? I have no idea what this thing does but it is keepimg me from finishing my engine swap.*
NO!
You need the wiring diagram I attached to this post.
You will need the distributor out of the 79. It should be a Motorcraft unit.
You will need to buy a Ignition Module for a 79 Jeep, or a 79 Ford F-150 Pick up.
Both are the same thing. V-8 or I-6 are the same.
Advanced Auto sells them for as little as $16.
You will need an ignition coil. Again, about $15.
If you can afford it, go with the Distributor Cap Adaptor, Distributor Cap, Rotor, Plug Wires, and TFI ignition coil from a Ford F-350 with a 460 CID engine WITH EEC for the TFI Coil and TFI coil wire,
Ford F-350 with a 460 CID engine WITH OUT EEC if you want the round 'can' coil.
Don't forget the ignition resistor wire if you are going to build a harness.
(you only need one of these)
84 Ford F-350 WITH OUT EEC for the 1.35 Ohm factory resistor wire.
76 Chrysler New Yorker with 400 CID V-8 for the dual porciline 'pot' type resistor.
(the Chrysler resistor will have two resistors built into it, use the 1.4 Ohm side, not the 5.0 Ohm side.)
The gold 'Module' from your 77 is the Prestolite unit.
It is a piece of crap. It will not work with the distributor you have for your V-8.
Avoid it at all costs.
*It appears from my painless instructions that I also need a voltage regulator.*
Depends on what alternator you are using. If you are using a Prestolite, Motorola, Ford, Chrysler or anything but an Delco, you will need a correctly connected alternator.
Find out what alternator you have, and I'll try to find you a wiring harness diagram.
So Many Cats, So Few Recipes...
