Let me see, you are looking for the wiring harness side of the connectors...
If you want the module side of the connectors, get a new module.
You need two connectors, one for the power, a two wire connector on your jeep.
The second, for the control wiring, should be a four wire connector for your jeep.
The DuraSpark connector for the power connection, Standard Ignition P/N S629 (this one will work for two or three wire connectors)
The DuraSpark connector for the controls connection, Standard Ignition P/N S-698.
Standard Ignition products are sold at Car Quest parts chains, along with a lot of other parts chains.
Is this what you are looking for?
Good luck, Aaron.
