Re: I think I\'m going to buy a Welder...
Alec - make sure you get a MIG welder with an external gas supply that is at least 125 amps or more with variable power setting and variable wire feed rate setting. I recently tried out a friend of a friend's flux-core wire feed and I think it is pretty useless junk. I REPEAT - DO NOT GET FLUX CORE!
Spend 5-600 dollars, and after 3 years when you have done umpteen mods and laid 17 miles of bead on your Jeep, you'll be writing back in to thank everyone. A welder is the best investment a true Jeeper can make.
FYI - I use a Daytona MIG 140 amp. It was $600 new and I bought it from my father used for $400. I consider this to be an excellent choice for your average Jeeper.
One last thing - getting the hang of it takes a while - it can be VERY frustrating when you first start out. A roll cage is not the best thing to start on. Build yourself some steering box braces and stuff to start out.
Chuck Hadley
Chuck Hadley
