I need a manual transmission expert
2225 Views 15 Replies 6 Participants Last post by  CJDave
My '84 CJ7 w/ T176 4 speed has problems........I was plowing snow and went to shift from reverse to 1st and the shifter locked up and wouldn't move and the Jeep was stuck in either 2nd of 3rd gear. I put the xfer case in low range and got it back to my garage. I (stupidly) wedged my foot against the shifter and pushed on it and it came loose, but now is sloppy and the Jeep is still stuck in gear and the shifter just moves around in circles.
Where do I start? I assume the shift mechanism is messed up someplace. Can I access this without pulling the transmission out? How does the shifter come off? Transmissions are not my field, put what the hey, I can take anything apart......putting them back together has sometimes been an issue.
Also, I have an '80 CJ7 spare parts car that used to have a 4 cylinder engine with what I think is an SR-4 4 speed. If I have to will this transmission bolt onto my 258? I think it has a Dana 300 transfer case.
Either way, I'd like to get it resolved because it's snow season here in Michigan and I'm getting too old to shovel.
Loose nut behind the wheel
Born and raised in Jeep-Town
1 - 16 of 16 Posts
Loosenut, Remove the floor plate so you can get to the top of the trans. At the base of the shifter there is a round metal retainer, push it down and turn it counter clockwise. The retainer and the shifter should pop out. If the end of the shifter isn't broken off, look inside of the trans, you will see the shift rails. You need to take a long screwdriver and move the rods so that the notches line up. If the shifter isn't broken drop it back in and it should shift. If it is broken, you will probably have to pull the top off the trans to get the broken piece out. This can all be done without pulling the trans.
Always happy to help another Right Wing Conservative. Roger
Thanks, Roger/ I'll get right on it. Damn. I wanted to watch football all day.........
To temporarily get yourself mobile again you are going to have to pull the shift lever out and reset the shift rails to neutral and reinstall the shifter handle. You will have to loosen the boot and pull it up out of the way. Looking where the shift lever goes into the top of the trans you will see the there is a "ring" around the shift lever. Push down on this ring and give a turn counterclockwise (I think), it is the retainer clip for the shift lever. Once this clip is loose the shift lever will pull out of the trans. Take a flashlight and look down inside. You will see the shift rails and the notches that the shift lever rides in. At this point the notches will not be aligned because the trans is in gear. Take a long screwdriver and line them up (shifting out of gear) so that the shift lever can be reinstalled. The trans should now be in neutral. Basically your shift rails and/or shift lever are worn, allowing the end of the shift lever to come out of the notch during a shift. Best solution is to replace the rails and/or lever. Cheapest solution is to have the end of the lever built back up a little by a welder. You should also replace the retaining clip if it looks worn, but it is rarely the problem.
"My other car is a BULLDOZER"
See less See more
I don't think you have a big problem, you've just got it stuck on the detent/lockout pins. Remove the
shifter knobs from the tranny and t-case. Remove the floor plate with the shift boots over the
transmission. Push down on the retainer at the base of the tranny shift lever and turn (counter clockwise
I think) about 1/4 turn. The shift lever will come out.
You will now see 3 shafts with slotted tabs. Line up all the slots in the middle, remember that they work
the opposite of the way they are shown on the shift knob. To shift into reverse, you would move the knob
to the right and back but this moves the left rod forward.
When you have all the shaft slots aligned, put the shift lever back. While you are here, you will see the
two tapered pins that hold the shift lever base in, wrap a hose clamp around the housing to keep the pins
from coming out. You may have knocked one of these out when you put your foot against the shift lever.
Try the shifter, if it works replace the cover.
Don't force anything, the shift rods should move rather easily.
See less See more
Loosenut,
You should feel real comfortable with the advice having gotten the same answer three times.
All 3 of you were right. I had it fixed in a matter of minutes. Only thing bothering me is what is worn? I was surprised that the shifter is flat on both sides. I always thought it had a round ball on the end, but as I said it's flat on both sides. Looking at my 4WD Hardware catalog, those parts are fairly expensive. I wouldn't want to buy parts I don't need. How can I tell what needs to be replaced? I really would like it fixed, as this is the third time it's locked up, but the first time I couldn't get it loose.
2
Mine's been that way the 13 years I've owned it and the previous owner told me about it. Mine doesn't
make it all the way out of reverse sometimes. I have to shift it back into reverse and move the rod to
the neutral position.
The end of the shift lever should be flat on each side.
See less See more
I'm no expert but alot of top loader transmissions wear out the shifter towers, I looked in the fall/winter 1999 4wd hardware catalog on page 99, and think that item numbers #22 and #25 might most of the problem. (maybe when you shift the lever has some slop that allows it to pop out the rail grooves? ya know that spring pushes it up pretty hard)
3/4tonYJ
My Jeep Page
4
/wwwthreads_images/icons/tongue.gif Hi Nut....glad to see that you got going again so easily. The shift gate problem you experienced is due to.....and I say this gently.....uh, sloppiness. Yep, when you do not "draw" the perfect "H" pattern with that lever when you change gears, you rub the sides of the rails and the lever and it wears them out, and eventually there is room enough to squeeze through, leaving the shift rail close enough to the detent that the ball POPS IT BACK and PRESTO you are in gear but the stick says "neutral". This was a BIG problem with badly worn Brownies in older trucks. If the driver got sloppy, the wear allowed him to leave a gear behind and he was screwed. Ol' Dave would have to crawl under with a pointed bar and get it all lined up again for the driver while he drank coffee in total denial and oblivious to what had happened. There was, occasionally, some cussing about this little phenomenon, for all the good it did. Just remember to run a nice, crisp, pattern with that stick and you'll be fine./wwwthreads_images/icons/crazy.gif
See less See more
Then again, with my SR-4, my "H" turned into an "h" awful fast, losing 3rd gear. This, in turn, caused my shifting to become erratic ("Get in there you $%^&**!"), which caused me to wear the fork off the bottom of the shifter, which eventually broke. OK, so it was probably more than that. It didn't help that 2nd was there only on upshifts and reverse was a hold in pattern. I welded the shifter and beat on it some more, but the tranny refused to die. We drove it home with vice grips and screwdrivers, got kinda used to them, but cold with no tranny plate. Still have it if interested, shifts well (and will throw in the screwdrivers as a backup), still no 3rd, but heck, who plows in 3rd anyway.../wwwthreads_images/icons/smile.gif
JEEPN
'81 CJ-8 Scrambled!
See less See more
Thanks Jeepn, but I already have a spare SR-4. I would like to know it it's a direct replacement for my T176. I know the case is 1" shorter, but does that matter?
With all this good input on the T-176 tranny, can anyone recommend someone who is honest and got a clue like you guys who I could pay to go through my T-176 and freshen-it-up? My T-176 works in my 85CJ, but is sloppy. I just don't want to take it to any ole body. I am located in Lafayette, IN. Thanks, DuaneD
4
/wwwthreads_images/icons/tongue.gif Every now and then you can find an automatic ransmission shop where one of the guys likes to do manual shifts too. You can go door to door and find out. HOWEVER, it is rare for the chain-store shops like AAMCO to do manual shifts. ALSO...if you want to get it real tight again, there are about five places you need to build up with weld; the tranny guy won't want to, only YOU will. The shift rails are usually a little harder and they are often OK, the shift LEVER is not. It will need the nose built up, the little notches where the pins go, and maybe even the case cover where the pins go into the tower will have to be bored and bushed or bored and larger pins made. It CAN BE DONE.....I've done quite a few in trucks and pickups. I have even done a few Brownie remote shift towers. It is SO NICE when you get it all back together and the shift lever doesn't wander all over the cab.....lessee.....was that third?.....oh DRAT.....the shift lever knob knocked out the gas gauge..../wwwthreads_images/icons/crazy.gif
See less See more
DuaneD,
A few years back, I had a '72 Commando with a T-18 in it. It was noisy, and my neigbor told me he'd help me rebuild it. I got a Jeep manual with an exploded view much like the ones in 4WD Hardware's catalog. We took it apart, and while I was waiting for parts, my neighbor took off to Florida for the winter! He didn't tell me that he was leaving in a few days.........You know, I put that transmission back together myself, with the help of talking to a few guys who'd had a transmission apart. I must have done it right, because I had that Commando for quite a few years after that. I didn't have this great source of information then, either.
I guess what I'm saying is that if you're mechanically inclined at all, you could do it with the help of the guys on here. The hardest part was taking the big snap rings off. I didn't have proper snap ring pliers. I would definately go buy some now, and I just may take this bugger of mine apart when it gets warm outside.
The parts are all available from 4WD Hardware, but I'm not sure if they are the best place to buy them. Anybody have any info about that?
See less See more
6
/wwwthreads_images/icons/laugh.gif nice going Nut! Nothing like a self-taught, self-done project like that. Sometimes you need a dummy shaft to load the cluster, but heck, I was knocking transmissions (truck five-speeds)in the head in high skool.(didn't know I shouldn't be doing it)/wwwthreads_images/icons/crazy.gif Uh....dat wuz back in d' fifties./wwwthreads_images/icons/crazy.gif ERK! And I'm STILL wrenching? What am I, nuts? Oh well, at least now I do it for recreation./wwwthreads_images/icons/crazy.gif
See less See more
1 - 16 of 16 Posts
