hybrid axles.
936 views 10 replies 7 participants last post by  zooky
Yo
seems like I saw some hybrid Sammi/kick axles at trail tough a while ago but I cant seem to find them now.
Who makes these things?
John
#3 ·
supposedly stronger.plus they throw in front and rear r&ps of your choice...all for 700$
I have been a lurker on sammi sites for a few years now and it seems that the sammi rear axle is really weak if you go to larger tires. want to avoide breakage before it happens.
John
#4 ·
Well untill someone tells me differently, all they are Sami axles with a diferent housing? All Zuk rear axles are the same size. LJ, SJ, Sammie, SideKick, all have the same Dia and spline count. How is a hybrid and stronger. Can someone explain???????????
Hi -
Our Hybrid rear end was built in order to resolve the breakage issue of the ring and pinion when using lower ratios of the original smaller Samurai or front Sidekick-type ring and pinions. The front Sidekick ring and pinions or lower ratio Samurai gears - when used in the rear - are subjected to about 70% of the load duty and are prone to breakage during the first year or so. I personally have broken two 5.12 sets, two 4.62 sets, and two 4.30 sets before I finally figured out that using that size gear in the rear was just not big enough to handle the strain from low geared t-cases and 31"+ tires. Since using the Sidekick rear R&P's - which requires the Hybrid housing to accommodate the larger REAR 3rd member - we have had a ZERO failure rate. It also makes for a very cost effective gear change package. It is very convenient for people to receive a front 3rd member with Sidekick front gears, a rear 3rd member with Sidekick rear gears, and a Hybrid housing - all set up for them and ready to bolt in for $649.00. It can be found under "Drivetrain" on our web page. If you purchase lockers, we will also install them for you at no extra charge.
Brent
Trail Tough Products
1-877-789-8547
www.trailtough.com
