Hub Gasket vs Silicon
361 Views 3 Replies 2 Participants Last post by  jeepgod
Is it necessary to replace the gasket between the 4x4 hub assembly and hub or can I use some type of sealent. A parts store mentioned silicon sealent would be sufficient, but is there a better product I sould consider?
Tim
Dirt is good. Speed is good. Scabs are good. Life is good.
'80 CJ7, 258, 31x10.50, o/w stock
i would use a gasket if at all possible call warn or superwinch they can send you some but it depends what i did was us the gasket and put Indian Head gasket maker on it works great
I also try to use a gasket if at all possible, with a skim coat of silicone or gasket sealer, for things like that, and like diff covers. It's not as messy as using just silicone, and I think it gives you more 'give'.
Just my opinion,
Good luck
Pete
88YJ,4"susp,33"BFGMT,9kwinch,homemade swingout,258,999,4.10,weber32/36,GMHEI,one moonguy/wwwthreads_images/icons/smile.gif
See less See more
i always run a sealant.. just dont over due it.. you only need a small beed around it.. for as much as i take the hubs off for service.. i dont waste my time with a gasket..
