How to Remove Corner Lens on Front End 96\'
I have a 96' and need to change out the front corner lens, the headlight is fine and the amber bottom lens is fine...
I removed the to top screws off the trim and looked around and I can not find anything else to remove... I'm stuck...
I went to get a Haynes or Chilton book but was not able to find one.
any help would be great!
Re: How to Remove Corner Lens on Front End 96\'
You have to pull the whole headlight door assembly to get to the screws for the side marker. You can barely pull that side bulb with it installed, but there's no chance for the reflector/lens assy. Look in Haynes Ch12-Sec12.14 at illustration 12.14, possibly on P 12-12: there are 2 phillips screws on top of the headlight door pointing down and 2 nuts on studs pointing back directly behind the main front blinker.
Thanks alot, that helps me out perfect...
I did not see the lower two nuts before, comes right out know... (laughing)
David
