how to put my pic in signature
1.4K views 33 replies 12 participants last post by  KevinOfCanada
How do I put a pic of my zuc in with my signature?
87 Samurai JX- S-10 Buckets. Cherry Bomb exaust. 2" lift shackles, 3" calmini springs, 30-9.50 Wild Cats
It didn't look that deep, or I wouldn't have told you to go on through........
#32 ·
badzuki, that is WAY TOO BIG!
Samurai202, you need to just get a pic of you Zuk flexing or just on the trail. Mine is small and everyone can see what it looks like. Might not want to do the other one, just a thought? It is hard to see the tire in the big pic's!
If anyone needs to get there pic's re-sized go to this web-page...
http://www.jpegcruncher.com
Here is some info on image sizing...
Sizing images can be tricky, so here are some basic directions and suggestions. Please realize that these are generic directions, and they may not match what you see in your image editor. Most software does, however, come with a manual that you can reference in case you need more specific directions.
The first thing you should check is the resolution setting in your camera or scanner software. Try to keep your resolution setting at under 150 dpi. Don't use high resolution unless absolutely necessary for image quality. The higher your resolution, the larger in kilobytes your image is going to be. We recommend keeping your images UNDER 50kb for a single image in an auction, and UNDER 20kb apiece for multiple images in an auction.
The second thing to be aware of is that most image editors don't automatically display the image in its actual size (in area.) Images are normally displayed in a standard size so you can see the whole image easily. After you have opened your image in the image editor window, click on the menu option Transform (or Resize - same thing.) There should be an option under that menu to Resize, Resample, or Redimension. Click on this option. You should see a box somewhere on the screen that says "maintain aspect ratio" - make sure that this box is checked. You should also see somewhere on the screen a display of Width and Height in pixels. Try not to exceed 450 total (Width plus Height) pixels, or your image will be too big. Now look for 3 boxes - WSCALE%, HSCALE%, and DATA SIZE.
The data size box will display the image size in kilobytes - you should aim to keep this number under 50. You can manipulate this number by changing the percentages in either the WSCALE% or the HSCALE% boxes. Once your image is sized, click "OK". You might want to now further enhance the image (this is optional and may not be necessary.) Your image editor should give you the option to increase brightness, darkness, sharpness, etc. On the menu bar, look for an enhance button (or something to that effect.) When your image is displayed to your liking, just save it and it should be ready to upload!
You can also try a compression utility such as http://www.jpegcruncher.com (free site) or the Jpeg Optimizer available for download at http://www.downloads.com Jpeg Optimizer is not free, but some say it is very good!
-Brian
ULTIMATE ZUK
http://www.geocities.com/brianconrad1/
#34 ·
Who says paint doesnt have capability to resize?
You first select the whole image that you want resized, if its more than the page big then hopefully you have a wheel mouse so you can scroll up with using the box select. Ok so now you have the whole image you want resized selected go to Image_strech/skew. Hit 75% for both vertical and horizontal. If its not what you want you can then press Ctrl-Z to undo and retry. Once you have the size where you'd like it, then pull the bluish/greenish border tight around your image.
Remember that when you save that the *.bmp files are much larger than the *.jpg ones, so save as something.jpg.
