Guest
·I want to eliminate the dimmer switch/poteniometer & just have the dash lights at full brightness all the time. How can I do this? Do I need to jumper two of the three wires together with a certain Ohm resistor????
In reply to:
The red/green wire is hot 12V when the lights are on, and the red/yellow feeds the lights
[/ QUOTE ]
Hmm that isn't clear at all is it? Doesn't even make sense...Screwed that up didn't I?![]()
One end of the pot (controler) is tied to ground, the black wire. Thats OK.
Hmmm, R/Y is feeding the bulbs switched hot power, R/B is taking the other end of the bulbs back to
the control, and the resistor is between the return and ground, depending on the position. So, if the
R/B is grounded, (No resistance to dim the lamps) you should be full bright. So you would Jumper the
Black and R/B together to get the ground without resistance.
In reply to:
Tag and insulate the 3rd black wire (it's ground), so you know what that cut off wire is at a
later date... Just tie the other 2 together.
[/ QUOTE ]
Thats just wrong!![]()
I hate these fine line schematics! If they grouped 3 lines and left a space between the next 3 lines
(like your supposed to, per every drafting standard I have ever seen...) it would be tons easier to trace...
Steve, you had it nailed. good catch. I screwed up.
Sorry, Wild bill!
