How do you attach cable to the drum. Cable clamp inside the drum? My drum has a hole to insert the cable but I don't know how to secure it.
It's a Warn 8274 winch.
Thanks,
Pigpen
Most winches I have spooled have a small terminal (like goes to your battery) that clamps to the end of the cable and a screw attaches to the spool. This is not meant to support any pulling, only to allow the cable to be connected to the spool for a starting point...
<a href="http://www.tennessee4x4.com/toyota">
you will have to take the cap off of the drum support, thread the wire rope though the hole in the drum, put a clamp on it, then shove the clamp into the drum and reinstall the drum support cap. real easy.
dan
Good things come to those who do research!!
