Guest
·Trying the get the stock (I think it's stock) carburetor off the 4cyl engine of a 1981 CJ5. The Haynes manual says to remove the fuel line (I'm almost postive that would be the steel one) from the carburetor. This steel hose attaches to the carb with two nuts. One of them is about 1" and it has a 1/2" nut going into it. When I turn either of them, the steel line turns as well. Eventually, if I keep this up, it will get kinked. I don't want that. How do I remove the fuel line from this carburetor? I'm trying to get to the fuel pump to see if it's working. And if it is, I plan to rebuild the carb so I need to get this line detatched from it no matter what.
These are the numbers I took from the Jeep:
Top of engine on passenger side: 10002948
Driver side of engine below manifold: 10012189
Carburetor: Rochester VaraJet II - 17081791 2520DMP
-Dorian
www.4Low.com
-Dorian
www.4Low.com
