How much psi should the external pump have for the 16v?? I have found one that has 34-45 psi and is adjustable. IS that enough for the motor? Thanks everone that has helped me on this conversion!!!!!
The Haynes manual reports:
8v TBI - 24 to 30 psi
16v MPFI - 29 to 37 psi
The pump I was looking at appears to be too high a pressue. You seem to have found a pump that operates in the desired psi range. What kind of pump is it?
