Im not sure how much my 82 CJ7 is lifted. I took some measurements. If youve got any ideas lets here them. The previous owner said id had Add-a-leafs but i think it is slightly larger than that.
Drivers Side Rocker to Ground- 24.5 in
Pass. Side Rocker to Ground- 24.5 in (No sagging between sides
Rear Crossmember- 23.5 in
Front Bumper- 24
Top of Windshield frame- 73.25
Top of front tire to bottom of fender flare- 4.75
Top of rear tire to bottom of fender flare- 6.75
It has 33x12.5 r15 ties on 15x8 wheels.
Stock should be about 20" from ground to rocker panel. Your tires will make that a little taller. You can get lift with body lifts, shackle lifts and spring lifts. You could have one of these or a combination of all three. It probably is just an add-a-leaf with the combination of tire size thats giving you the lift. Just my opinion but hope it helps.
Scott
