on the bottom, mine has what looks like old radiator hose cut up and the rad just sits on it and at the top it has 2 screws with rubber bushings that look like they're only supposed to hold it to the core, but because there's not enough support from the bottom they had to hold it UP too and one side has broken off the plastic tab. how is the bottom really supposed to be setup?
I'm not sure if the brackets are seperate but there are 2 saddles that have 2 molded rubber (not old hose) pieces that the radiator sets in. The top 2 screws or bolts should not have any weight on them they just hold the radiator tight against the core support. Hope this helps,
