I wasn't going to post again, because this guy is going to kill himself.
That's his choice.
I just hope some of my friends or family members aren't in the area when he totals his Jeep...
Street racing is stupid, and only done by brats that have a small penis complex, and can't do anything correctly.
If they could do it correctly, you would see them at the race track trying to take on the REAL MEN.
Here are a few things 'fishntruck' either missed, or incorrectly stated....
SPS makes the strongest connecting rod bolts, followed by ARP.
Milodon BUYS it's bolts from several different vendors, and quality varies.
All AMC connecting rod bolts are less than desirable.
NO AMC connecting rod from the factory is satisfactory for racing.
ONLY the 390 and 401 have steel connecting rods, but they are poor quality.
Only the 390 and 401 offered forged steel crankshafts. Surprisingly, the forged steel crankshafts are seriously tough units, and will withstand up to 1,000 horsepower.
Only the 390 and 401 came with four bolt main caps.
Not all 390's and 401's have four bolt main caps.
All had weak cast iron main caps.
All had weak main cap bolts, and will require a bottom end stud kit to race.
The oiling system of the 290 through 401 engines is pretty close to useless.
For high speed operations (4,000 RPM and above) you MUST get oil to the front drives,
IE, distributor drive, fuel pump eccentric, and the timing chain.
This is an easy modification, and can be done for as little as $5.
On the subject of timing chains,
USE A TRUE, DOUBLE ROLLER TIMING CHAIN.
Not just a 'double roller'...
There IS a difference, and it means a lot above 4,000 RPM.
Consideration must be given to getting oil to the #7 & #8 connecting rods.
This last journal is absolutely starved for oil on all AMC V-8 engines.
Extra attention must be given to the camshaft oil galleries.
Often times, cam bearings will not be installed correctly, or the galleries themselves do not meet correctly.
Lifter bores are a concern on may AMC V-8's.
Oversized lifter bores are common on AMC engines, and incorrect lifters fit will destroy the camshaft, and even maybe the entire engine.
Push rods, rocker arms, rocker arm mounting, and valve guides are all inadequate for racing on AMC V-8's.
Push rods are small and weak.
Rocker arms are one of two verities, and both are inadequate for even short periods above 4,000 RPM.
Rocker arm mounts use too small diameter of bolts to hold the valve train geometry correctly.
Valve guides are knurled from the factory, and are usually not bronze wear surfaces.
AMC heads do just fine in the flow department, so normally all we do is clean them up.
Some will need to have machined to accept hardened valve seats.
AMC head castings are prone to thin spots due to lack of quality control.
Shifted sand castings, and use of wire to hold the moulding pieces together present particularly hard problems to overcome.
Odd casting pockets trap steam and create hot spots and misshaped head expansion.
AMC engine cylinder cases (engine blocks) have the same problems.
Shifted sand casting moulds, wires, and generally poor machining make for a disaster waiting to happen in may cases.
If you do decide to have an AMC V-8 built,
1. Have the engine cylinder case THOROUGHLY checked.
Sonic check for thickness in the cylinders.
The bottoms around the main webs in particular are often so very thin the block is junk.
2. Check the cylinder case deck surface.
Again, sonic check for thickness first, then check for cracks, especially radiating out from bolt holes.
3. Carefully inspect rods and crankshaft.
Thrust face surfaces are VERY important here.
ALL AMC V-8 RODS SHOULD HAVE NEW ROD BOLTS. PERIOD.
4. If you use studs, DO NOT BOTTOM THEM OUT!
If you bottom out main cap studs, it will crack the block, I guarantee it.
5. DO NOT "PORT OUT" THE HEADS.
AMC heads do just fine on their own, and they have hidden thin spots, so anytime you grind on them, it's dangerous.
Just clean up the port, and make sure you port match with the gasket and intake.
6. DO NOT skimp on the head job.
Use good components, and make sure the machining is done correctly.
Swirl polished valves add real usable ponies to the AMC engine, and cost is nothing.
7. Intake tract should be a set.
Use a matched set on the intake tract. Like the Edelbrock Cam, lifters, timing chain, intake and carb.
Make sure you use the headers they recommend.
The AMC engines are very sensitive to header tube diameter and length.
