I checked my '94 service manual (SM) for the door removal sequence. It is pretty close to the steps below. You won't have to worry about disconnecting the wiring if all you want to do is replace the hinges.
The SM procedure described removing the spring, lower hinge pin retainer, lower hinge pin (using a soft mallet against the pin, and against a pair of locking pliers on the pin shaft to finish the removal), and installing a temporary bolt in the lower hinge while the upper hinge pin is removed.
Cross-posted from another forum:
You need a spring tool, which looks like two metal plates with a C notch in one end, hinged at the other, with a nut and bolt through it. That tool is hard to find. Remove the spring.
You also need to press the old pin out and press the new one in, trying to hammer it will only bend the hinge.
You need a firm support for the door while the hinge pin is out. (it is heavy and easily unbalanced)
Aside from all this, all you need is a socket larger than the pin, a C clamp that will fit over the works, another, smaller C-clamp, a block of wood and a helper to change it out.
The block of wood needs to fit inside the hinge right next to the pin, and cut to fit tightly so as to keep from collapsing the hinge. The helper needs to be strong enough to hold the door up while the pin is out. Put the socket over the head of the pin and use the C clamp to push the pin out.
Use a set of pliers if needed to finish the job once the C-clamp has bottomed out. Use the smaller C clamp and socket to push out the bushings.
Put the new bushing in place, using the socket to allow the bushing to extend past the bottoom of the hinge. Put in the new pin, using the socket on the tip side to allow the C-clamp to seat the head.
