I'm running a CJ external slave cylinder in my YJ (using the YJ clutch master cylinder.) Everything bolted together fine...I gravity bled the system (i probably used half a bottle of brake fluid) ... I cannot get the clutch to disengage completely. The pedal goes to the floor much easier than it used to...when you press the pedal in, you can see the slave cylinder pushrod move forward, but it doesn't disengage the clutch completely.
The soft/easy pedal would lead me to believe that it's air in my clutch line...Is there a better way to bleed the clutch system than just gravity bleeding it? Anybody else have any suggestion as to what it could be?
Thanks,
pablo
Thanks,
pablo
