Guest
·I remember CJDave touched on how he creates his dual battery isolator with a heavy duty, constant service relay wired to an oil pressure switch. Here's the question...If you're cranking the engine (trying to start it) you don't have enough oil pressure to push the switch, right? So you are only on one battery to start the engine... If that battery is dead, how do you get juice to the starter...Can you run a second wire to the solenoid that is switched ( ) power, so you can flip the switch, turn the solenoid on hot, and jump yourself? Would you want to? It seems to me that it would be a lot easier to run my solenoid activation power off of the ignition switch...have it on accessory and you've got one battery. Key off and you've got one battery. Turn the key on, you've got two...winch, start, whatever. What am I not thinking of? This seems easier and cheaper....(which, if I've learned anything in my limited jeeping experience, is usually worse than harder and more expensive /wwwthreads_images/icons/smile.gif).
