My homemade bridge rectifier to convert my AC stick welder into a DC source using SCR's is working. The SCR's were bought surplus from Princess Auto for $9.99 each. I used a 300 ohm resistor and a small diode to connect the gate of each SCR to the anode to convert them into simple diodes. I mounted them to 2.5" aluminum channel for a heat sink and have temporarily mounted it to a board for testing.
I ran a bead with some 3/32 6013 rod first to see if the diodes heated up. At 80 amps, no trace of heat. I turned it up to 100 amps and burned a full rod. Barely perceptable that it was warming up the heat sinks. I then switched to a 1/8 7014 rod and turned the welder up to 130 amps input. After burning the rod up, I checked the heat sinks. They were now warm, and the diodes were hot to the touch. That is probably the limits. I will have to use some heat sink compound on the base of the diodes to make sure they are conducting heat will to the aluminum channel. I ran the stick to the "-" side and the ground clamp to the positive output. I sure seemed effortless to start the arc and there was no tendancy of the rod to stick to the work on first striking the arc. I wondering if this is a result of the reverse polarity setup?
Next step is to experiment with using a lamp dimmer to control the input of the gate of an SCR to control the output. The lamp dimmer will chop up the ac phase to produce ac pulses at 60 hz, but of varying duration. I will run this thru a bridge rectifier to get dc pulses to input to the gate.
Ultimately the goal is to power an air cooled tig torch.
Anyone know the limits of material I can weld using 110 amps? I'm thinking that should be good to around 3/16 on mild steel or stainless.
Here's a picture of the bridge as tested this afternoon.
