I'm thinking about trying to use my mig welder as a power source for a low amp dc tig. My little mig is a Cebora (Pocket mig) unit. Output of 30-110 amps.
I opened the welder up to look at how easy it might be to tap into the power and it looks a cinch. The manual says the contactor is not live at all times. But I don't see a relay in between the transformer or rectifier and the two main leads. How does the contactor get connected when you squeeze the trigger on a mig? Is there a connection made inside the gun? If so, I can just cut into the two obvious leads that go to the gun and ground cable.
Also, wondering what polarity a gas mig operates on. It looks like the ground clamp is in fact ground. So I was planning to put two welder lugs on the side of the case so I can switch ground to whatever polarity I choose, as I understand on DC tig you run negative on the tungsten electrode. Also, what size and type of electrode and gas nozzle / funnel thingy would work best for welding light gauge stainless and mild steel (around 100 thou or less)? Do I run pure argon, or do I run a body shop type mix for mild steel and stainless?
