Hi everyone few ?
424 views 8 replies 2 participants last post by  **DONOTDELETE**
Hi I just started rebuilding my 73 cj5 from the ground up. I got this jeep from my Dad whom I had helped build it to what it is now. Up till now I knew very little about jeeps (what upgrades, convertion, and interchangeability) In the last few weeks I have learned alot just from reading your postings and replys but still have a lot of questions. But that is why I am here.
My cj5 has a amc 390, t-15, d-20 transfer, dana 30 front w/power lock, 44 rear w/track lock, ramsy pto front, warn electric rear. I striped it down to the frame and started getting thing lined up on what I would like to do. This is where I need help for you guys. I would like to convert to a 4 speed and keep my d-20 because of the pto. But with limited space I am not shure on what tranny to go with? I have read about the ford t-18 6.32-1 but not shure on convertion length. Also the hard to find jeep t-18. I would appreciate any feed back. I also need info on where to find dana 44 w/disc to change out the 30. I heard the 77-80 scout axle cut down is the way to go. Suspention is also a big question. Right now I have to the stock tall pack springs w/13 leafs fornt and 11 rear. It has a hole made revesal kit that rasies about 2". It also has a 2" body lift. Should I go SOA with different springs or just a u bolt reversal? Any info would be great. I am working on getting you guys some pics. Thanks
Hopefully you will get much more detailed replies than mine but maybe this will get you started.
I think the Ford T-18 will be your best bet. Availability and price should be much better than the Jeep T-18. Check here for info on length http://www.off-road.com/jeep/tech/convtrans/convt18.html
77-80 Scout axles are only a couple inches wider than wide track CJ axles. Instead of cutting them down I would add caster angle and go. I am slowly in the process of this swap now. Waggie fronts have better caster but may be harder to find with passenger drop and are a little wider than the scouts.
I would definitely go spring over. Especially since you live in Colorado.
If you give a little more info on what you expect from your vehicle (wheeling wise), the smart guys around here will inundate you with info.
K-16
#3 ·
Ford T18 is about three inches longer overall. I did this a few months back, and the new shaft in front was three inches longer. The T18 is a little longer than the T15, and then a 1 inch spacer between the the transmission and transfer case.
I would say yes on the SOA, but thats only my opinion, depends on what the Jeep is going to be used for.
pbm
74 cj5,304,t18,2.46 ts d20,30f,44r,soa,MORE buggy front,35's,Rci's,5pt,full cage,air,etc.
Support Search and Rescue.......Get Lost! /wwwthreads_images/icons/shocked.gif
#4 ·
Why 77-80 Scout avles what is wrong with a 76 Scout? Thanks:
Rodney C
1985 CJ7,302 V8,T18,D20,SOA,Shackles Reversed, 35" BFG AT's, Fiberglass Tub & Front End...
1990 Samurai,87 drive line,SOA+2.5" Add-A-Leaf,4.16's,5.12's,33" BFG's Mud's,Pony Carb...
Oh Good, I thought my 1976 D44's were not as good a 1977 for a second :) My 1976 has disk brakes. Thanks:
Rodney C
