I'm sure some of you already know this....but for the uninitiated, like myself, it'll save you a bunch of time and frustration.
Get two long (6 inches or longer) bolts the same thread size as the two transmission bolts that go into the block right above the oil pan.
Cut the head of the bolt off and cut a notch into the end of the bolt where the head was so that you can use a flatblade screwdriver to remove it.
Thread them into the holes and use them as a guide for the transmission.
The bolts will help keep the transmission from tilting and turning while making sure it's straight. The input shaft should slide into the pilot bearing very easily.
When I first removed my transmission to replace the pilot bearing, it took 2 people, a tranny jack, and the better part of an hour to get it bolted to the engine.
This time, after replacing the input shaft bearing, a syncho, and fifth gear, I used the two bolts that I fabbed up. It only took myself, the tranny jack, and about 10 minutes from loading it onto the jack to being bolted to the engine.
So for those of you who didn't know about this....think about it the next time you have to tackle a transmission on your rig.
