Go have it aligned. They'll tell you if the ball joint6s are bad. Or if yoy want to check yourself just jack it up untill the tire comes off the goround a little. The stick a pry bar under it and lift up to check for play. If there is no movement in the ball joints then I'd venture to say your axle is bent.
Al
My web page
Al
My web page
